2000 silverado 4wd issue
Old Nov 9, 2012 | 06:13 AM
thirdgenbum's Avatar
Default 2000 silverado 4wd issue
i got a buddy with a 2000 z71 and it won't go into 4hi/4lo when selected on the dash, but it goes into 4wd when "4auto" is selected. is there any obvious issues that i can tackle initially? my first thoughts are either the switch itself or the actuator. any good starting places guys?
thanks in advance!
Old Nov 9, 2012 | 03:17 PM
Last Call's Avatar
TOTM: January 2007
thanks in advance!
I had a similar issue and changed the switch. It fixed the problem and has been good for about a year.
Old Nov 9, 2012 | 03:46 PM
nonnieselman's Avatar
usually its either the switch itself or the encoder motor on the xcase..
Old Nov 10, 2012 | 09:36 AM
Gadgetized's Avatar
I had the same problem. I bought a motor, and later read t could be the switch. I removed the switch, and soldered every connection on the back as it was suggested somewhere I read. It has been two years working fine. Try to solder it first, it could be a free fix. If you need the motor, I have a brand new one that hads never been installed if you are interested.
Old Nov 10, 2012 | 11:24 AM
black00chev's Avatar
Slowest turbo build ever!
If you know someone at a dealer have them scan with a tech2 first. My truck started throwing service 4WD lights and I checked with the tech2 and said faulty switch. Replaced the 4WD selector switch and haven't had an issue since.
Old Nov 11, 2012 | 09:30 AM
Awesome, thanks guys, I'll let ya know what I find
DrX
Aug 28, 2015 08:50 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
MileHighSierra
Jul 22, 2015 11:19 PM
samg430
Jul 20, 2015 10:12 AM
Suburban2500
Jul 19, 2015 04:50 PM
