2/4 drop versus 3/4 drop
Old Mar 14, 2008 | 11:54 AM
Reckless's Avatar
Still moddin'
Default 2/4 drop versus 3/4 drop
There is a good likelihood I will swap a 6.0L LS2 aluminum engine into the truck, should I go with a 3/4 drop since the weight on the nose will be less?
Opinions?
Old Mar 14, 2008 | 10:00 PM
StrokerAce03's Avatar
How soon are you planning the engine and how soon for the drop? If you're wanting it level bear in mind that the rear needs to be 3" lower in the rear usually to make it level. Personally I'd go with a 3/5 and if the engine raises the front a little it'll be level.
Old Mar 14, 2008 | 11:44 PM
terravast4's Avatar
I agree. you will enjoy the 3/5 what size tires you running up front? 55sidewall on a 20" rim will rub unless you got like a 255 or something like that.
Old Mar 14, 2008 | 11:45 PM
Reckless's Avatar
Still moddin'
So then a 2/4 would net about the same without getting too low. I occasionally take dirt roads out here when we go trail riding.
Right now it has the stocker steel wheels, so I can run whatever I want to when the time comes.
Old Mar 15, 2008 | 01:38 AM
black06's Avatar
will a 55 sidewall rub with a 2/4?
Old Mar 15, 2008 | 02:45 AM
terravast4's Avatar
if you are running 20's it will be close I had to go down to 45's on my3/5. I was runnint 275/ 45 r20 if you shortened the width to around 255 it might be enough to avoid that front fender lip which will hit during hard bumps.
Old Mar 15, 2008 | 03:15 AM
RandomHero's Avatar
Obviously that would depend on the rest of the tire dimensions. Do you have any idea how tire sizes work?
That's almost as bad as asking "Will a goodyear rub on a 4/6 drop?"
walledition
Feb 24, 2026 03:27 PM
Velocity1
Oct 12, 2015 10:39 PM
Superman09
Sep 25, 2015 05:55 AM
fortune46x
Sep 16, 2015 08:18 AM
