1st to 2nd shifts at high rpm...
Old Jul 19, 2006 | 08:05 PM
johnrusso1987's Avatar
Default 1st to 2nd shifts at high rpm...
I ran into a little problem with my truck...When I shift from 1st to 2nd it wants to shift near redline or I have to back off completely to let it shift. This came out of nowhere last night on the way home from my local track.
Also, when I floor it, the engine redlines immediatley instead of taking off almost as if it were being shifted into neutral.
What kind of problem am I looking at here? Torque Converter?
Thanks
Old Jul 19, 2006 | 08:10 PM
nonnieselman's Avatar
sounds like the tranny is shot?? but thats just my uneducated guess... more will chime in shortly...
Old Jul 19, 2006 | 08:20 PM
LARRY01Z28's Avatar
sounds like a internal tranny problem to me.
are you getting any codes for slipping?? (SES codes)
Old Jul 19, 2006 | 08:23 PM
FLT's Avatar
FLT
FormerVendor
Sounds like your 2-4 band is just about toast. You said when you punch it, it red lines almost like in neutral. When this happens are still in first or second?
Old Jul 19, 2006 | 08:30 PM
I havent gotten any codes or faults in my programmer, i just drove it again to double check. It hangs real bad in the 1st to 2nd shift. After that everything is fine...until I step on it and then it just redlines until I let off and then grabs a gear.
Old Jul 19, 2006 | 08:31 PM
Vince... this is in any gear, it goes to downshift and just redlines.
Old Jul 19, 2006 | 09:26 PM
FLT's Avatar
FLT
FormerVendor
Does it slip like this in reverse? What about if you shift it manually?
Old Jul 19, 2006 | 11:01 PM
sliderbkt's Avatar
I have pretty much the same thing going on. Under normal driving 1st holds to about 4200rpm then shifts. I scanned it while driving and the 1-2 solenoid is calling for the shift, but it doesn't happen. Then when the 2-3 comes it goes straight to 3rd from 1st. But, every other gear seems fine.
I changed the solenoid, but that didn't help. I changed the drivers side solenoid, hopefully that was the right one.
Old Jul 20, 2006 | 11:42 AM
sliderbkt's Avatar
Vince, Is the drivers side solenoid the 1-2 or did i switch the wrong one?
Old Jul 20, 2006 | 02:22 PM
James B.'s Avatar
If it does it from a stop I think the band is ruled out. You also mention nothing about losing fourth. If the band were fried you'd be having more trouble getting into overdrive than into second.
I think you've got forward clutch issues. That could be from low pressure from a boost valve malfunction, pump, or maybe even fluid level. Could be also that the piston has a torn lip seal or something like that. Whatever the case, it sounds like loss of apply pressure to me.
