14 bolts
Old Sep 9, 2006 | 11:41 AM
Quik's Avatar
5 year bitches!
Default 14 bolts
now i know the SSS has them in the 2wd models now do the VHO have a 14bolt as well? and if so do all models have them?
can you get a 14bolt with disks or is it only drums, im in need of a rear
Old Sep 9, 2006 | 03:13 PM
Mort's Avatar
Cool
The 1500HD and 2500LD have the 9.5" semi floating rear 14 bolt and depending on the year you can get discs. The problem is they are 8 bolt not 6.
Old Sep 9, 2006 | 05:02 PM
nightrunner's Avatar
Mr. Obvious
as far as i know the vho and sss are the only 6lug 14bolt 9.5" semifloating rear axle they make and its hard to find one in disc brakes but the did make them for a while
Old Sep 9, 2006 | 07:09 PM
6.0caddy's Avatar
I heard you can swap out the axels from a 8 lug 14 bolt to a 6 lug 14 bolt. That what I am going to do.
Old Sep 9, 2006 | 08:32 PM
You can pull the axles and swap the backing plate a rear disc backing plate.
The bolt up procedure is the same as the 99-04' model GM trucks.
You can swap over the disc hardware onto your 14 bolt axle.
Baer Brakes makes a rear disc conversion kit for the 05' & up 1/2 ton trucks that have the rear drum brakes.
If you look at the hardware kit, you will see that is a lot of factory components to do the conversion.
The kit is about $1200.
I guess there are a few different ways to do this conversion, but it can be done without getting rid of your rear axle.
Jim
natejk
Nov 15, 2016 08:05 AM
Justin87gn
Sep 10, 2015 12:06 PM
2004gibbstruck
Sep 7, 2015 06:05 PM
iregret
Sep 7, 2015 01:20 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
