14 Bolt Swap Questions
Old May 16, 2013 | 01:12 PM
foose04's Avatar
Default 14 Bolt Swap Questions
Hey guys, looking at my options to swap over to a 14 bolt from my 10. Seems like a smart/safe thing to do at this point.
I was told these are my donors for a direct 6 lug swap...
04-06 VHO trucks
05+ 2wd SSS trucks
06-07 GMT800 Vmax trucks 2wd and 4wd
07-09 GMT900 Vmax trucks 2wd and 4wd
09+ 6.2 equipped trucks both NHT and Denalis
GMT900 SUVs equipped with the 6.2 like Denalis and Escalades
Found this on Craigs.
GM 14 bolt, 3.42's and 6 lug, semi-floater. Said to be out of a light 2500 but not sure what year. It's got a drum brake setup.
I called and he believes it's a fit for me. He says it was match to his 95 silverado so that makes me wonder if it's still match for me.
Says its got the GM POSI as well, I know the 10 bolt one was crap, is 14 bolt a good unit? It's a drum setup, how bad is swap to disc?
Thanks for the help guys.
__________________
Old May 16, 2013 | 01:35 PM
foose04's Avatar
Here's the pic's he sent me and god bless, looks like it's off a damn railroad train. Brackets look correct though. Needs a good cleaning and disc swap if it's doable.
Fo'Free bling included...
Old May 16, 2013 | 02:16 PM
Area47's Avatar
only thing you have to watch out for the rear end itself is the bearings.
Old May 16, 2013 | 02:37 PM
PaulyC's Avatar
heres a pretty good thread for info:
https://www.performancetrucks.net/fo...p-pics-489403/
i believe the nbs rear ends are 1" wider then the older 14 bolts so it wont hurt to measure your 10 bolt then measure the new axle just to check.
Old May 16, 2013 | 02:43 PM
Jake99's Avatar
Got a little more rust then id like but I would have him check the distance leaf to leaf cause they change from body style to body style but idk if the 95 to 99+ would match but I know the 70s and 80s dont fit the 90s.
Old May 16, 2013 | 03:11 PM
nonnieselman's Avatar
yea thats gonna need a lil more power to turn
Old May 16, 2013 | 03:15 PM
foose04's Avatar
He said it was off a 2wd and that it's a match for mine. Is there anything else I need him to measure other then leaf to leaf?
How strong is posi? Is detriot locker my safest bet?
Yeah I agree, but I'm starting to get more nervous about mine letting go and putting me in a bad situation. Mine already has a fair share of wear and tear.
I'm thinking a built 14 bolt and doing a long bar setup up to the frame rails. Then I can hit this redhead pretty hard out the gate.
Old May 16, 2013 | 04:04 PM
DO IT!! I agree, getting up on the fine line of scary with the 10 bolt.
Old May 16, 2013 | 05:26 PM
fastjweb's Avatar
Foose, if thats out of a 95, then it will work, but you have to move the spring perches on it. I believe its 2" overall differance from spring perch to spring perch between your 10 bolt and that one. It will be easy to move them once you measure it compared to yours. As for the disc brakes I do not know. I thought Atomic did this swap in his old truck if i'm not mistaken.
Alot of good info in this thread, they did disc brakes too...
https://www.performancetrucks.net/fo...ight=bolt+swap
Old May 16, 2013 | 05:39 PM
TIM Z's Avatar
11 sec. Truck Mod
Any G80 factory locker sucks and won't hold power.
I broke the one in my Dmax just putting in wet grass , I couldn't believe it .
But rock it and see you never know .
And that rust ain't bad at all I've seen ones that make that look new .
