14 Bolt Swap Complete - Pics Inside
Old Apr 2, 2012 | 03:27 PM
  #81
Rompn's Avatar
Post
In case it hasn't been said yet, there was also the option of getting a 2WD, torsion bar front end, 3.73 10 bolt rear with "locker", on factory 20's. I know because I have one I bought new off the lot in 05. Has a 5.3 and is an ext. cab. I'm looking at doing a 14 bolt swap but a full floater version. Anyone have a write up on a swap for that version 14 bolt?
Old Mar 9, 2015 | 10:11 AM
  #82
Brendan Weaver's Avatar
Default 14 bolt sf swap
I have a 2004 Silverado 1500 z71 crew cab with a 10bolt with the g80 locker. I did a 6.0 swap, lvl3 performabuilt with a 3200 stall yank. I'm right around 520 fwhp. You can guess what happened to the 10bolt. My question is what is the budget route to upgrade from the 10 bolt? And the year rpo code, and model of the donor vehicle . Thank you in advance
Old Mar 9, 2015 | 01:01 PM
  #83
Atomic's Avatar
I have a gauge for that
The budget route is to fix the 10b with a better carrier. Its not terrible after you replace the g80.
Old Mar 9, 2015 | 01:16 PM
  #84
GMCtrk's Avatar
Something's wrong if you broke the stock rear end with only 500 hp.
Old Mar 9, 2015 | 03:33 PM
  #85
tgui's Avatar
I'd slap a Eaton Detroit TrueTrac in.
Also, how often did you change the oil in your diff? Were you doing burn outs?
Old Mar 9, 2015 | 03:34 PM
  #86
tgui's Avatar
When I've seen stock rear ends go, its often because of lack of maintenance.
Old Mar 9, 2015 | 04:12 PM
  #87
Atomic's Avatar
Or giving it a lot of throttle around a corner...thatll do it...
Old Mar 11, 2015 | 11:42 PM
  #88
It Was changed 8 months ago. it's a crew cab so it's heavier then all these rc plus I'm gonna spray it, it's built to run 800hp safely on spray so I wanna be prepared and get slicks. Right now if I don't roll on it it won't hook up until 3rd. All I see is people bashing 10bolts and tall say strengthen it. And it's a ftl not a yank lol
Old Mar 17, 2015 | 03:32 PM
  #89
axisT6's Avatar
For this to work with your factory wheels, you will need to bore the center out to about 4.25". Solidaxle.com has the 6 lug hubs, you just need to find the appropriate 14FF axle.
OHsixLS3
Dec 27, 2016 09:30 AM
chacho44
Aug 17, 2015 03:36 AM
Ammadien
Jul 22, 2015 08:50 PM
4B11T
Jul 13, 2015 03:48 PM
NuckenFuts
Jul 9, 2015 08:45 AM
