14 Bolt Swap Complete - Pics Inside
Old Jun 17, 2008 | 11:13 PM
Last Call's Avatar
TOTM: January 2007
Default 14 Bolt Swap Complete - Pics Inside
I had the 14 bolt swapped in today. The 2005 VHO 14 bolt was a direct bolt in.
For those interested in doing the swap...
The factory disk brakes will bolt up.
A 1320 to 1350 conversion u-joint is needed with the 1350 straps. (I will eventually put a 1350 yoke on the driveshaft.)
The driveshaft does not need to be cut.
The 14 bolt is much heavier and the axles are way bigger! I would say close to 50% larger.
Old Jun 17, 2008 | 11:29 PM
2005 Silverado's Avatar
SPAM HUNTER
Just wondering, haven't searched at all, do you know, say i got that same axle (my truck being rear disc) would i just hook the brake lines to the new axle without modification?
Also looks good, it looks like a tank compared to the 10 bolt.
Dustin
Old Jun 17, 2008 | 11:48 PM
06-crewhauler's Avatar
where did get the 14 bolt junk yard or what i want one
Old Jun 18, 2008 | 12:10 AM
ZZebes's Avatar
a minor correction, the stock Yoke is a 3R not a 1310
Old Jun 18, 2008 | 12:11 AM
ZZebes's Avatar
and congrats on the axle lol
Old Jun 18, 2008 | 02:30 AM
laynlow77's Avatar
you changed your name!!!!
looks much beefier, hopefully that holds up
Old Jun 18, 2008 | 07:10 AM
Bill Reid's Avatar
I want one... anybody know a good GM salvage yard with national search and shipping capabilities? Please PM me. Thanks
Good job on the swap!
Bill
Old Jun 18, 2008 | 09:14 AM
Last Call's Avatar
TOTM: January 2007
Dustin
You need to remove the disk brakes and bracketry and bolt it onto the 14 bolt. The disk brake do sit at a bit of an angle, but bolt up ok.
I got the rear end in gmfullsize.com, and someone was parting out an 05 VHO.
Uh oh, I told the guy at the driveline shop I needed a conversion u-joint and I believe that is what he said it was. I will check today and verify what adapter u-joint it was.
Bill
Thanks! I looked for a few months before I found one. They are not easy to find either. It only ended up costing me $850.00 shipped. I could not pass up that deal.
Old Jun 18, 2008 | 09:17 AM
Last Call's Avatar
TOTM: January 2007
Thanks. You are going to need one soon as well!
I changed my name after Bill, Henry, and Julien suggested it. What can I say, I never leave the bar early. LOL
Yes, I am hoping this rear is stronger and does not give me as much grief as the 10 bolt did. I still need to install an LSD. The G80 that is in there now sucks!
Old Jun 18, 2008 | 09:18 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Damn J that didn't take you long! Any noticible sotp differences? Congrats!
