14 bolt sf backing plate flanges???
Old Oct 22, 2013 | 02:01 PM
JMCKAMY's Avatar
Registered User
Default 14 bolt sf backing plate flanges???
Does anyone know where I can get a pair of weld on 14 bolt SF backing plate flanges??? I'm SWAPPING MY FACOTRY 10 BOLT DISC SET UP ON TO IT.
Old Oct 24, 2013 | 12:07 PM
JMCKAMY's Avatar
Registered User
I guess not. lol
Old Oct 25, 2013 | 08:47 AM
JoeyGC5's Avatar
pm 1fastbrick, he might know a guy with a spare set or two
Old Oct 25, 2013 | 10:02 AM
DrX's Avatar
DrX
Or contact axisT6 on here. He sent me some new flanges after putting together my 14 bolt (https://www.performancetrucks.net/fo...-421388/page3/) as they needed to be re-clocked.
Old Oct 29, 2013 | 04:20 PM
JMCKAMY's Avatar
Registered User
I've sent pm's to both already no reply. Thanks for the help though. I may have them made here local.
Old May 12, 2014 | 03:17 PM
NuckenFuts's Avatar
I also need a set of these, Does anyone have a line on two of them? Need spacers or new backing plate to weld to end of shaft to bolt up my 10 Bolt disk breaks.
Thank you to anyone that can help.
This is what im looking for
Old May 12, 2014 | 03:33 PM
Atomic's Avatar
I have a gauge for that
PM the same two guys again
Or you can make some spacers with bolts and nuts or DOM tubing, the caliper will just sit crooked.
Old May 12, 2014 | 05:22 PM
NuckenFuts's Avatar
Do you still have that truck you did your swap on with the nuts and washers? Any major problems doing it that way? I will have to follow your build if I cant find the spacers.
Old May 12, 2014 | 07:16 PM
Atomic's Avatar
Not the truck but I still have the axle. When I swapped it out of my silver truck into the white one I welded on flanges to mount the axles, although I never had a problem with the nuts and washers. I made the spacers out of 1/2" nuts I drilled out. Kinda shaddy but worked perfectly.
Old May 12, 2014 | 10:40 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Sorry, but just for the Record...
I had a few set's made on my dime, but after a select few people complained about the price and 1 person burned me on a custom set, I decided not to waste any more of my personal time on them. Not to mention, I had to front my own money for materials and machining. I then taped and deburred them my self to help keep the cost down.
