14 bolt rear.. Drums or Disk?
Old Jun 4, 2008 | 09:55 AM
Last Call's Avatar
TOTM: January 2007
Default 14 bolt rear.. Drums or Disk?
The 14 bolt 9.5" rear I bought should be here Friday. I am debating on which brake set up to go with. The rear end is coming complete from drum to drum with e brake cables. I also have the Baer Eradispeed rotor kit for the rear brakes.
What would be better to go with, drums or disk?
Old Jun 5, 2008 | 09:01 AM
Last Call's Avatar
TOTM: January 2007
Nobody???
Old Jun 5, 2008 | 09:08 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
I'd leave the drums, at least for now. If you don't like them you can convert later. I personally like my rear drums better than the '03s which had 4 disc. I do have the larger rotors and upgraded calipers up front though.
Old Jun 5, 2008 | 09:50 AM
Last Call's Avatar
TOTM: January 2007
I might just keep the drums and sell the Eradispeed's. I guess I will install the rear with the drums and see how I like it and go from there.
Old Jun 5, 2008 | 09:59 AM
blue2003ls's Avatar
I would run the disks since your portioning valve is probably set up for disks currently. I think there is a difference in the volume of fluid required for disks and drums and possibly even a difference in pressure.
Old Jun 5, 2008 | 10:08 AM
1989k1500's Avatar
disc.
Old Jun 5, 2008 | 08:45 PM
7845's Avatar
Banned
Old Jun 5, 2008 | 09:56 PM
xchevyx24's Avatar
i like my rear drums i think the truck has better feel and more braking power then my 02 4 wheel disk
Old Jun 6, 2008 | 08:51 PM
MonteCarlo31's Avatar
I vote for discs. I went from disc disc (F-150) to a Disc drum (silverado) and the drums don't have the stopping power under a load. It also seems that they have more pedal travel then others out there (I believe hydroboost cures this). I know they are two different trucks but w/ the same trailer and same bed loads the Drums just seem to fade as the stop continues.
flatblack83
Jan 3, 2026 07:10 PM
chopperloco
Jul 10, 2016 10:45 PM
bighouse
Sep 27, 2015 12:37 AM
hackrst
Sep 2, 2015 05:27 PM
