14 Bolt Arrived Today
Old Jan 4, 2016 | 07:50 AM
2002_Z28_Six_Speed's Avatar
WHAAAT??? Aren't aftermarket axles (at least for fbodies) not much more than that?
Old Jan 4, 2016 | 08:09 AM
zz454Chevelle67's Avatar
Originally Posted by 2KRedSilverado
Post some pics when you get around to it, I'm in the same boat. Gonna swap my disks into my 14b
I will post up pictures as I go.
Old Feb 28, 2016 | 10:45 AM
Planned on swapping in 14 bolt Saturday morning but after pulling axles out I found axles tubes and diff had a lot of sludge caused by moister and oil mixing. Axle bearing are ruined but axles are ok. All carrier and pinion bearings seem ok as well. Ended up taking the housing to a car wash and cleaning inside.
Cleaned up nice
Old Feb 29, 2016 | 11:27 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Nice! That's how I clean mine before modifying them.
I hope you got the moisture out right away though... They start flash rusting right away and if you planned on re-using any of the bearings they will do the same.
Old Mar 4, 2016 | 06:36 PM
I sprayed everything with brake cleaner and then WD-40.
Old Mar 4, 2016 | 06:40 PM
10 bolt finally out. Took off work and made time to do it.
Old Mar 4, 2016 | 08:10 PM
tgui's Avatar
^^ I've done the same!
Relaxing, a few beers and wrenching is downtime for me as well.
Awesome work brotato!
Old Mar 5, 2016 | 01:38 PM
14 bolt in and finished. Swap was amazingly easy. Never had to break open brake lines to swap out drums for my disk, it was simple. Calipers are canted at 45 degrees and looks a little weird but fit perfect. Feels good knowing it's better than original.
Old Mar 6, 2016 | 02:21 AM
Suburbazine's Avatar
Did you put 2.75qt of oil in or did you use the 2.0 spec (wrong)? It's possible to have it come out the fill plug at 2qt due to angle.
Old Mar 6, 2016 | 07:58 AM
2KRedSilverado's Avatar
So what is it supposed to be filled to? I just finished up my 9.5 swap with a TA cover and I'm in 4 quarts and I still can't touch the fluid through the fill hole with my pinky...
