1 shim, 2 shim, 3 shim or no shim?
Old Apr 2, 2012 | 05:13 AM
stevenc's Avatar
Don't raise the line pressure, and use 1 shim. My last transmission was a junkyard trans with around 90k miles on it I used 1 shim and stock pressures with a 2400 stall torque converter. The tires squeeled (nearly had tire spin)! on the 2nd shift and I had to bump down the pressure in the tune. It lasted nearly 25k miles ontop of the 90k it had before I swapped it out when my converter clutch went out. It still works great.
The 2 shims + raised line pressure had to have been a hard shift...Quick chirp is all you want, you dont want a squeel.
Old Apr 3, 2012 | 10:24 AM
Originally Posted by 06sierra5.3
...Im trying to learn how all this stuff works and what exactly they are. Its overwhelming
Thats the only reason why I was trying to clarify it
Old Apr 3, 2012 | 11:19 PM
06sierra5.3's Avatar
thanks guys. 1 shim and stock line pressure is what it will be.
Old Apr 11, 2012 | 08:36 AM
mongooseboy000's Avatar
I used 2 with my 3200 stall and had Justin from Blackbear adjust the pressure with tune. It's perfect not harsh in light throttle and neck snapping at WOT
GXPJAY
Nov 5, 2015 06:49 AM
twake_410
Sep 25, 2015 10:09 PM
mhotrodscooter
Aug 23, 2015 04:41 PM
1bad2k
Aug 18, 2015 09:50 PM
iregret
Jul 27, 2015 10:31 PM
