1 blown G80!!
Old May 14, 2005 | 01:32 PM
  #51
redaddiction's Avatar
Originally Posted by moregrip
I need another job
or a sponsor
Join the club. I would even be happy if someone gave me a dollar at this point.
Old May 14, 2005 | 02:52 PM
  #52
hellbents10's Avatar
LS1Tech Sponsor
i don't think it was too much low end torque. the 10.5 is damn strong even with a G80. a quick killer of any differential is wheel hop. wheel hop will take out just about any gear type diff (non spool). the stockers such as a g80 will just go quicker. with his caltrac's on there this may not have happened.
Old May 14, 2005 | 02:55 PM
  #53
moregrip's Avatar
what a rush!
maybe the wheelhop WAS worse than it felt
Old May 14, 2005 | 03:18 PM
  #54
Weedo's Avatar
not that it means anything
the timeslip says
r/t .4
60' 2.6
1/8 11.2
mph 70
1/4 16.6
mph 92
That looks about right...... Where you expecting to run quicker than that with an underhood BBQ-grill?????
Old May 14, 2005 | 03:29 PM
  #55
14 Second Truck Club
Thanks for the info!
looks like the open carrier is about $200 bucks and the locker is about $400 bucks. That's $600 plus install,
Can I do this myself? I really prefer to do all my own work
The locker comes already assembled. The case is 2 pieces, so all you have to do is seperate it, put the locker in it, the reassemble. There is a wing nut that holds the locker together, once the case is all assembled you just remove the wing nut an dthe carrier is all set. Then just install it with the ring gear, NEW bearings and ring gear bolts, and set your backlash.
Maybe not as easy as it sounds, but you should be able to handle it. You will need a dial indicator and magnetic base. Check your backlash before disassebly, and reset it the same.
Old May 14, 2005 | 04:55 PM
  #56
Breeze's Avatar
11 Second Truck Club
Damn here everybody is talking up the detroit locker I thought the Eaton was the preferred rear around here.
Old May 14, 2005 | 05:13 PM
  #57
James B.'s Avatar
Eaton still rules the street.
Old May 14, 2005 | 05:30 PM
  #58
zippy's Avatar
the eaton is the most common because many feel the detroit locker to be excessive. to me it's just right.
as for your diff there grip, i'd see if the dealer will warrenty it for you. i know where i work it wouldn't be an issue. that's the same that comes in the 8.1 suv's and it should take the power. if you can get them to do it you can either sell the locker they replace it with or if you are really in good with them they will put an open diff back in it's place. either way i'd try warrenty first to try to knock down some of the cost.
Old May 14, 2005 | 05:34 PM
  #59
Breeze's Avatar
I started gettin a lil worried there as long as it will hold up to a low 13sec truck with e/t streets witch it will right? Ill be fine.
Old May 14, 2005 | 07:59 PM
  #60
GoldenVelvet's Avatar
It has never been touched, truck has 6,800 miles on it
I guess it could be a defect?
I say warranty it. Just dont let them know about the blower under the hood and it happened at a track.
