07 Saab 97x rear diff. oil change is GM whale sperm required?
07 saab97x i5.3 AWD same as trailblazer.
Attempting to change the rear diff. oil I think I have the correct fuild.
?1.Like what doe’s top off only mean?
?2.Should the GM additive Whale sperm be added to oil?
?3.I bought 2 quarts is this enough fuild?
?4.same ?s for the front diff.
Thanks
Thanks
no the owners manual is not available today.
so this gear oil must be Synthetic stuff I have is regular.
the diff. cover has one extra long bolt I didn't take note of it's location? would you happen to know where it goes? thanks
I started this diff oil change a couple weeks back, yes I think you are correct about the E brake cable I think I tucked it up out of the way when crawling under vehicle.
I will take a close look if I remember correctly there was a small bracket.
I think the longer bolt wasn't the 12 o'clock but either the 11 or 1 o clock do you know where the longer bolt goe's.
dam I should have clicked a image before disassembly.
Thanks TB
Thanks TB
Iv'e reassembled the rear cover however there is one extra long bolt however I didn't take note of where it was located.
been looking for a emergency brake cable that if I remember correctly is attached to the diff. w/ this longer bolt but didn't see the cable.
wish I took a image before disassembly. been searching the net couldn't find much but this attached image aurther wrote it's a trailVoy notice there isn't a E cable attached to diff.
