07 Saab 97x rear diff. oil change is GM whale sperm required?
07 saab97x i5.3 AWD same as trailblazer. Attempting to change the rear diff. oil I think I have the correct fuild. https://cimg2.ibsrv.net/gimg/www.per...eb9d4c549f.jpg https://cimg3.ibsrv.net/gimg/www.per...102f5f66ea.jpg ?1.Like what doe’s top off only mean? ?2.Should the GM additive Whale sperm be added to oil? ?3.I bought 2 quarts is this enough fuild? ?4.same ?s for the front diff. Thanks |
Still have the owners manual?
I think its SAE 75W-90 Synthetic Axle lube Meeting GM spec 9986115 API spec GL-5 I believe 80W-90 is the front diff. |
no the owners manual is not available today.
so this gear oil must be Synthetic stuff I have is regular. the diff. cover has one extra long bolt I didn't take note of it's location? would you happen to know where it goes? thanks |
Is there a bracket for the brake line or emergency cable near by? That's likely where it goes.
I started this diff oil change a couple weeks back, yes I think you are correct about the E brake cable I think I tucked it up out of the way when crawling under vehicle.
I will take a close look if I remember correctly there was a small bracket. I think the longer bolt wasn't the 12 o'clock but either the 11 or 1 o clock do you know where the longer bolt goe's. dam I should have clicked a image before disassembly. Thanks TB |
The cable should fall back into place and be close to one of the bolt hole locations.
I crawled under the vehicle didn't see a e-brake cable there did appear to be a small tube connected to each rear wheel right next to the bump stop.
Iv'e reassembled the rear cover however there is one extra long bolt however I didn't take note of where it was located.
been looking for a emergency brake cable that if I remember correctly is attached to the diff. w/ this longer bolt but didn't see the cable. wish I took a image before disassembly. been searching the net couldn't find much but this attached image aurther wrote it's a trailVoy notice there isn't a E cable attached to diff. https://cimg3.ibsrv.net/gimg/www.per...9dc904f506.jpg |
Maybe a bracket for the brake line that runs across the top of axle.
