07 Saab 97x rear diff. oil change is GM whale sperm required?
Old 04-04-2019, 08:56 AM
thebrain's Avatar
Default 07 Saab 97x rear diff. oil change is GM whale sperm required?
07 saab97x i5.3 AWD same as trailblazer.
Attempting to change the rear diff. oil I think I have the correct fuild.
?1.Like what doe’s top off only mean?
?2.Should the GM additive Whale sperm be added to oil?
?3.I bought 2 quarts is this enough fuild?
?4.same ?s for the front diff.
Thanks
Old 04-04-2019, 09:06 AM
MikeGyver's Avatar
You said whale sperm. Ha ha, ha ha, ha ha ha.
Old 04-04-2019, 11:17 AM
Custm2500's Rude Friend
1FastBrick's Avatar
Still have the owners manual?
I think its SAE 75W-90 Synthetic Axle lube Meeting GM spec 9986115
API spec GL-5
I believe 80W-90 is the front diff.
Old 04-04-2019, 11:49 AM
thebrain's Avatar
no the owners manual is not available today.
so this gear oil must be Synthetic stuff I have is regular.
the diff. cover has one extra long bolt I didn't take note of it's location? would you happen to know where it goes? thanks
Old 04-04-2019, 11:52 AM
1FastBrick's Avatar
Is there a bracket for the brake line or emergency cable near by? That's likely where it goes.
Old 04-04-2019, 12:10 PM
thebrain's Avatar
I started this diff oil change a couple weeks back, yes I think you are correct about the E brake cable I think I tucked it up out of the way when crawling under vehicle.
I will take a close look if I remember correctly there was a small bracket.
I think the longer bolt wasn't the 12 o'clock but either the 11 or 1 o clock do you know where the longer bolt goe's.
dam I should have clicked a image before disassembly.
Thanks TB
Old 04-04-2019, 12:27 PM
1FastBrick's Avatar
The cable should fall back into place and be close to one of the bolt hole locations.
Old 04-04-2019, 12:36 PM
thebrain's Avatar
I crawled under the vehicle didn't see a e-brake cable there did appear to be a small tube connected to each rear wheel right next to the bump stop.
Old 04-05-2019, 05:41 AM
thebrain's Avatar
Iv'e reassembled the rear cover however there is one extra long bolt however I didn't take note of where it was located.
been looking for a emergency brake cable that if I remember correctly is attached to the diff. w/ this longer bolt but didn't see the cable.
wish I took a image before disassembly. been searching the net couldn't find much but this attached image aurther wrote it's a trailVoy notice there isn't a E cable attached to diff.
Old 04-05-2019, 12:55 PM
Merctech2's Avatar
Maybe a bracket for the brake line that runs across the top of axle.
Quick Reply: 07 Saab 97x rear diff. oil change is GM whale sperm required?
