06 Silverado 14 bolt 6 lug swap from 94 4x4
Old 09-28-2015, 08:56 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Good deal.
Glad to see you finally getting it finished. Now get it painted and installed!!!
Old 09-30-2015, 06:43 AM
kvrL33's Avatar
Nice work man. What would be a fair price for one of these axles right now? I have one that I won't be able to use. It has the 4:10 posi from the factory with 65k miles.
Old 10-01-2015, 11:32 PM
Wolftrk99's Avatar
When you figured that out let me know!!! Im interested in one, after trans, cam and steering/sway bar are finished....
Old 10-03-2015, 06:47 AM
willhorne22's Avatar
Thanks FastBrick those brake flanges worked great. Here is a bunch of pictures of me getting it painted. I ran into 2 problems when getting ready to install it. I didn't need a new U joint my 06 silverado came factory equipped with a 1350 u joint. I found this out after I pressed my old u joint out lol. I also bought the ruffstuff simple swap kit but I forgot about my 6" lift block. The ruffstuff bolts are only 10 inches long =(. So new 5/8 x 3.0 x 16 bolts are on order.
Old 10-03-2015, 10:30 AM
1FastBrick's Avatar
Nice!!! Can't wait to see it under the truck and get your impressions.
Old 10-04-2015, 08:00 AM
Waiting on those new U-Bolts................Of course I didn't notice i had the wrong bolts till Friday so now they wont be here till Tuesday =(
Old 10-04-2015, 02:45 PM
1FastBrick's Avatar
Nice! too bad about the bolts...
Old 10-05-2015, 07:22 PM
2002_Z28_Six_Speed's Avatar
Awesome thread. Very impressed. Used to live right by LRAFB. Darn those Southern snowstorms.
Old 10-07-2015, 07:38 PM
Thank you sir, First test run I thought my truck was going to break down. Turns out my axles weren't even close to being ground down enough. The rotors were wobbling and grinding the caliper bracket. It sounded terrible. You have to grind down the axles for a while like atomic said 30 min per axle. Check, double check, and then check again.
Old 10-07-2015, 08:53 PM
I have a gauge for that
Atomic's Avatar
Told ya
Probably 1/8" or so off the total diameter.
Quick Reply: 06 Silverado 14 bolt 6 lug swap from 94 4x4
