06 Silverado 14 bolt 6 lug swap from 94 4x4
Thanks FastBrick those brake flanges worked great. Here is a bunch of pictures of me getting it painted. I ran into 2 problems when getting ready to install it. I didn't need a new U joint my 06 silverado came factory equipped with a 1350 u joint. I found this out after I pressed my old u joint out lol. I also bought the ruffstuff simple swap kit but I forgot about my 6" lift block. The ruffstuff bolts are only 10 inches long =(. So new 5/8 x 3.0 x 16 bolts are on order.
Thank you sir, First test run I thought my truck was going to break down. Turns out my axles weren't even close to being ground down enough. The rotors were wobbling and grinding the caliper bracket. It sounded terrible. You have to grind down the axles for a while like atomic said 30 min per axle. Check, double check, and then check again.
