03-07 vs 99-02 transfer case?
Old Nov 2, 2015 | 01:13 PM
97aztecgt's Avatar
Default 03-07 vs 99-02 transfer case?
I have found several transfer cases for the 99-02 trucks that are decently priced, but I can not locate a 03-07 transfer case that is below $800.
I have a 04 z71 4l60, dash switch and I'm wondering if a transfer case from a 99-02 will work with no modification?
Old Nov 2, 2015 | 01:22 PM
Atomic's Avatar
I have a gauge for that
Its probably the electronic motor type vs the manual shift type to explain the cost difference. If they are the same type then I am pretty sure they are the exact same between those years.
Old Nov 2, 2015 | 02:30 PM
97aztecgt's Avatar
I can find a 99-02 for electronic shift all day long for $200-$300. However, a 03-07 electronic shift is at a minimum of $800.
Seems like the 99-02 transfer case front drive shaft still spins while in 2WD, but the 03-07 does not?
Old Nov 2, 2015 | 03:20 PM
smokeshow's Avatar
Mod with training wheels
The 03-07 transfer cases drag the clutches and turn the front shaft in 2wd as well.
Old Nov 3, 2015 | 08:36 AM
Atomic's Avatar
On my 04 manual case the front drive shaft was still. I think the key there is it was a manual tcase not the electronic one. I like the manual cases better. Feeling it clunk into engagement is much more satisfying than watching a little flashing LED.
Old Nov 3, 2015 | 08:38 AM
tgui's Avatar
I dunno. I love mine in auto mode. It puts you in 4WD seamlessly, then back to 2WD when you hit a patch of road with no snow or ice.
Old Nov 3, 2015 | 09:22 AM
smokeshow's Avatar
I like not having to think about a 30lb drive shaft having to instantly go from completely stopped to matching wheel speed when I hit 4wd at 75mph. You never know when someone next to you on the highway is going to need a good thrashing.
Old Nov 3, 2015 | 09:33 AM
Atomic's Avatar
What do you mean? The operators manual says to never exceed 40mph in 4wd, surely you aren't violating the operating instructions!
Old Nov 3, 2015 | 09:43 AM
smokeshow's Avatar
I don't even speed. Sometimes I just dick around on the highway at/up to 75mph. lol
Old Nov 3, 2015 | 09:55 AM
tgui's Avatar
I accelerate hard at times next to other cars, but to only clean the carbon deposits out of my engine.
Slow53
Oct 28, 2016 10:47 PM
97aztecgt
Nov 10, 2015 05:36 PM
Tuckin15s
Nov 9, 2015 06:17 AM
jdb11386
Oct 29, 2015 06:45 AM
lxcoupe
Oct 28, 2015 10:40 PM
