00 rear axle same from 2wd to 4wd?
May 31, 2009 | 07:32 PM
Will rear axle shafts from a 4wd fit in a 2wd?
Reply 0
May 31, 2009 | 07:34 PM
I don't see why it would not fit.
Reply 0
May 31, 2009 | 07:36 PM
i dont either but summit only list them for 4wd so i wanted to make sure before i bought them
Reply 0
May 31, 2009 | 08:11 PM
you need to list the specific appliction so people know which axle your refering to. I am assuming your refering to a 10 bolt in a truck. in 2000 would that be the new body style or the old body style.
I do know in the 14 bolt SF floater the axles are longer in the 4wd Vs. the 2wd version.
Reply 0
Jun 1, 2009 | 04:40 AM
Sorry it is a nbs and a 10 bolt.
Reply 0
Aug 25, 2009 | 08:09 PM
anything ever come of this? ive found a set of shafts from a 4x4 1500...wondering if they are the same length as my 2wd shafts.
Reply 0
Aug 25, 2009 | 08:52 PM
Quote: anything ever come of this? ive found a set of shafts from a 4x4 1500...wondering if they are the same length as my 2wd shafts.
I believe in the 10 bolt in the NBS 99-07 classic The axle safts are the same. How ever There may be a slight difference Between drum rear brakes and disc but I am not 100% sure. when in doubt call an axle manufacture, They will have the lengths for different possible options.
Reply 0
Aug 26, 2009 | 09:14 PM
i picked up a set of shafts from a 2000 4x4 8.6 axle. i guess i'll give them a shot and report back.
Reply 0
Aug 28, 2009 | 02:56 PM
Got the shafts in...they physically appeared to be exactly the same. I've cranked the truck up with it on jackstands and let it run in drive for about 5 minutes...all appears to be well. they were an exact replacement!
Reply 0
Aug 28, 2009 | 04:30 PM
a big smokey burnout confirmed that they indeed do work!
Reply 0
