Walbro 450 in 01 Tahoe bucket?
Old Jan 9, 2016 | 11:09 PM
Pro52R's Avatar
Default Walbro 450 in 01 Tahoe bucket?
So I'm in the process of doing my swap. I'm making my own hotwire kit. Should I just drill two small holes in the hat for the pump? Are you guys still using the standard connector walbro sends?
Also I have a plastic hat on mine. If I eventually do a bulkhead fitting, do I need a steel hat replacement?
There's not much room in the Tahoe bucket.
Old Jan 11, 2016 | 10:51 AM
shootermwc's Avatar
I'm about to do mine in a 00 silverado. Curious about this as well. I was going to use a separate relay and harness with a bulkhead fitting, but mine is going aftermarket EFI
Old Jan 11, 2016 | 02:09 PM
Atomic's Avatar
I have a gauge for that
I drilled 2 small holes for 10ga wiring to the pumps and used grommets and sealant to seal it.
Old Jul 18, 2016 | 01:48 PM
Fullpower's Avatar
Will epoxy hold up in a gasoline environment, as in JB weld ?
. I want to upgrade my OE pump wire size as well, run 12 gauge direct from stock fuel pump relay tab along frame and into fuel tank, and run a new pump ground wire out as well.'
factory wires look a little light, maybe around 18 gauge ?
Old Jul 18, 2016 | 02:13 PM
Atomic's Avatar
If you mean sealing the top of the bucket then yes, but if you mean submerged in gas I doubt it.
Old Jul 18, 2016 | 10:32 PM
BlueTexan24's Avatar
atomic where did you get your grommets at for this? I'm about to redo mine cause I just ran them to the connector on top and the smaller wire to the actual pump wires so I don't think it's gonna support as much as it should when I need it.
Old Jul 18, 2016 | 11:10 PM
Atomic's Avatar
From a generic grommet pack from a parts store, but if you want something better check out mcmastercarr: McMaster-Carr
Old Jul 19, 2016 | 08:52 AM
LongBlue's Avatar
Just as an FYI guys, Caswell Coatings makes a gas and E85 safe epoxy. Its used to seal the inside of motorcycle tanks. I used it to seal my homemade electrical bulkhead on my pump assembly.
40series
16
Mar 17, 2016 12:19 AM
bttlfed98gt
Jan 27, 2016 10:32 PM
TAPyvehc93
Jan 8, 2016 08:34 PM
