weldable bulkhead fitting?
Old Jan 4, 2016 | 05:30 PM
TAPyvehc93's Avatar
Default weldable bulkhead fitting?
So I was wondering if the is a 8AN stainless bulkhead fitting around? A regular bulkhead fitting with the nut on the back side wont work because there is just not enough room for a nut. I believe the fuel hat on the nnbs trucks are stainless so if I could just find a stainless bulkhead fitting I could just weld it to the hat and not worry about fitting a nut on the backside. Thanks!
Old Jan 4, 2016 | 08:42 PM
Atomic's Avatar
I have a gauge for that
If you trim the plastic you can just get the nut in there tight and spin the fitting to tighten it.
Old Jan 4, 2016 | 08:57 PM
TAPyvehc93's Avatar
Well the shop that did this for me did a sh!3tastic job ( thats why I am pulling it all back apart ) and they drilled the hole literally right to the edge of the hat. There is no way a nut will fit on the bottom. I know this sounds tacky but I was thinking about just JB welding an aluminum bulkhead fitting in there just so i don't have to use a nut on the bottom. I'm just not sure how the JB weld would hold up to gas and ethanol, but as long as it holds and seals I'm cool with it. Not like anyone is every going to see it.
Old Jan 4, 2016 | 09:10 PM
Atomic's Avatar
It would probably be ok, but why not just get a new bucket and try again to do a better job. They are about $40.
Old Jan 4, 2016 | 09:17 PM
03sierraslt's Avatar
That's exactly what I did on mine. All though mine is glued also.
Old Jan 4, 2016 | 09:34 PM
TAPyvehc93's Avatar
Just to be clear, I am talking about a NNBS flex fuel bucket/top. Not sure if they are the same. Where can I find one?
Old Jan 4, 2016 | 09:36 PM
Atomic's Avatar
Ebay if a used one pops up or a little more at a salvage yard
Old Jan 4, 2016 | 09:55 PM
TAPyvehc93's Avatar
I think I'll just try the Jb weld. It should be fine as long as it holds up to the gas and e85.
Old Jan 4, 2016 | 10:07 PM
Atomic's Avatar
Yea...as long as you dont get a gas leak and the truck blows up you should be just fine
Old Jan 4, 2016 | 10:20 PM
I used special glue, or I should say sealant.
