Walbro 255 or equivalent "kit"
Old Sep 26, 2020 | 11:52 AM
Mr. Breeze's Avatar
Yeah I don't need that much pump.
Your saying you bought the racetronix/walbro drop in module from summit?
Old Sep 26, 2020 | 01:50 PM
RedXray's Avatar
100% Redneck
Yep installed last November
Summit Racing TU432HP-2
Old Sep 28, 2020 | 07:15 AM
Merctech2's Avatar
How much Hp will that module support?
Old Sep 28, 2020 | 09:20 AM
Mr. Breeze's Avatar
From what I've read around 600 +/- horsepower.
Problem I have is, the module he linked has the old square style weak connector, my trucks wiring has already been upgraded to the new style connector gm went to. I'd buy that pump, but would literally have to convert BACK to the old square connector to run it.
If I could find that exact pump, with the updated connector, I would buy it no problem, but I'm not willing to hack up my wiring AGAIN to go back to the old style like the pump in that link... although I may have too if I can't find a solution...
Highly debating cutting the BS Venturi bucket crap and putting a fuel cell with a proper sump and decent pump in it. Otherwise the only other options I can come up with, is rigging an aftermarket 255 in it, completely disabling the Venturi function, and thus having to keep fuel levels at or above quarter tank at all times... Don't at all prefer this option.
Old Sep 29, 2020 | 04:01 PM
Mr. Breeze's Avatar
So, I contacted racetronix and then walbro directly, and the TU432HP module for the 99-02 trucks is on nation wide backorder and walbro claims it will be next year at the very earliest before they become available again, if ever....
Posting to hopefully save any others the grief of trying to locate one...
***** ridiculous...
ANY OTHER IDEAS to be able to maintain the Venturi bucket function??? Any other drop in pumps available?
Old Sep 29, 2020 | 05:42 PM
RedXray's Avatar
100% Redneck
Walbrofuelpumps.com says the TU432HP is in stock and allowed me to add to cart... didn't go any further.
Old Sep 29, 2020 | 05:55 PM
Mr. Breeze's Avatar
Yup, I did the same thing, but before I pulled the trigger and paid for the pump, I decided to email them first. Sure enough, within an hour they replied back with the info I just provided. I emailed back that I was able to ad the module to my cart on their website and that they should probably update the website to reflect their stock. I was nice about it, have not heard back yet, was towards the end of the day so they had probably gone home for the day.
Old Sep 29, 2020 | 06:10 PM
jclark10's Avatar
I don't get how there isn't an aftermarket for fuel systems for these trucks? Even given the car stuff should be similar? I have a returnless so I can't even run the drop in Walbro that is now on national backorder since I don't think they have a returnless version with a built in regulator. I am like the OP I don't want to buy a upgraded pump motor and try to hack up the bucket and lose the stock fuel siphoning functionality.
Its like everyone is having to make up all this custom stuff, and when it comes to upgrading fuel systems everything seems way more complicated than it needs to be with all the different fuel system changes over the years and everything.
My EVAP is clogged on my Escalade, so I am going to have to drop the tank again to clean the charcoal out of the lines and I really wish I could put at least some type of upgrade while I have the tank out instead of having to put stock stuff back in. Has anyone ever swapped a regular 4.8/5.3/6.0 pump with a L59 Tahoe Flex Fuel pump? I would imagine they flow more than even the stock LQ9 pumps?
Old Oct 6, 2020 | 08:41 AM
Mr. Breeze's Avatar
Yup, it's amazing that there doesn't seem to be any decent options for us, other than to hack up a factory bucket, or go with an entirely different tank and pump system..
So, it seems that racetronix/walbro, is "or was" the ONLY COMPANY that makes an aftermarket drop in module with a 255 or equivalent pump for the guys with Venturi style buckets?
To those of you THAT HAVE MODIFIED your factory bucket for a universal walbro 255, have you had any problems while under a quarter tank of gas during WOT launches? I'm not sure I would want to risk fuel loss at 6000 rpm on my build... Without having baffling around the pumps in the tanks on these, sure does seem to like a big risk at even half tank fuel level to me.
How low have you gone on fuel level during hard launches with these modified buckets, and seen it lose pressure?
Old Dec 9, 2020 | 12:48 PM
codered161's Avatar
Anyone running one of these https://www.highflowfuel.com/i-35468...yABEgKzmfD_BwE
or would the walbro 255 be good enough for 5-600hp?
