Swapping 04-06 tank into 99-03 then modifying the newer bucket for the older return.
Old Aug 30, 2019 | 06:15 PM
iregret's Avatar
Charlie Murphy!
After a bunch more searching I figured out that the leftward bound hose goes to the filler tube. The filler tube is different on the 04-06 tanks.
I went to a different yard from before. A wrecking yard that will actually let you pull your own parts. I intended to just grab a filler tube, but the evap was just laying in the cab so I grabbed it as well. Here's what $20 got me.
I'm not sure if I'll use the charcoal canister or not, but at least I have that option now.
Old Feb 22, 2020 | 02:50 PM
chris99gmc's Avatar
Use the filler tube from your 99 tank. Run the largest vent that you can so it won’t take forever to fill up at the gas station., if you’re Changing sending units(because you have to if You swap tanks to use the bigger bucket), you will need to reflash the PCM with the fuel tank PWM gauge table values flipped. Otherwise, the gauge will read backwards.
I remember also having an issue with the vents and routing for the purge solenoids were somewhat different. I think I ended up bypassing the line for the tip over valve to prevent the dreaded 30 minute long refills at the gas station.
in the end, I ended up tapping a 8an or 10an bung for my feed and used the stock feed for return.
Old May 4, 2022 | 01:07 PM
Dale2000swb's Avatar
Registered User
When you guys did the swap did your tank hit the cab of the tank in the front?
Old May 4, 2022 | 03:18 PM
iregret's Avatar
Charlie Murphy!
It did not.
Old Jan 11, 2023 | 05:38 PM
Logan Lombard's Avatar
Registered User
Default 05 gas tank in 03 gmc
Originally Posted by iregret
It did not.
hey I’m also doing a gas tank and pump swap I have a 2003 GMC and I’m putting a 2005 GMC gas tank and fuel pump and evap form the 05 my question is where did you put the fuel return or did you get rid of it? And is there any other problems I will run into thanks
rpm-inc
Oct 19, 2018 06:49 PM
Jake99
May 9, 2016 09:11 PM
TAPyvehc93
Jan 8, 2016 10:47 AM
Atomic
Jun 29, 2015 03:37 PM
Last Call
Jan 28, 2014 07:00 PM
