Surge Tank Mounting Suggestions, Pictures?
Old Feb 7, 2026 | 08:45 AM
smokinlmm's Avatar
Be careful with that Hobbs switch, if it fails you lean out under boost. I just run both of mine and return the fuel to the tank.
Old Feb 7, 2026 | 10:42 AM
HawkZ28's Avatar
5 Year Member
Originally Posted by MikeGyver
There's more room between the bed box and the outside of the bed, in the gas filler area, than you would think.
Sweet. I'll check that out. Have to dig in there for return anyway.
No issues with heating fuel on mild cruising through town/traffic, or is that more urban legend and dead head system problems?
Old Feb 7, 2026 | 01:13 PM
HawkZ28's Avatar
5 Year Member
While I'm thinking about it, did any of you return through fuel filler neck, and which kit did you use or what's the diameter of the filler neck rubber hose? Guess I could always measure OD when I investigate the available space in that areola too.
Old Feb 7, 2026 | 06:23 PM
smokinlmm's Avatar
No issues and I daily the truck in 100 plus ambient temps in the summer.
Old Feb 7, 2026 | 09:43 PM
RDF1's Avatar
DuNnO
5 Year Member
How much room do you have between the rear of the fuel tank and the rear axle?
Old Mar 5, 2026 | 07:10 PM
HawkZ28's Avatar
5 Year Member
I'll have to check. I seem to recall it being fairly 'busy' back there.
Old Mar 5, 2026 | 07:17 PM
HawkZ28's Avatar
5 Year Member
Started putting the tank and pumps together. Working on it while I wait on pistons.....ordered 2/11 and they aren't scheduled to ship now until 5/31, so I'm building as much of the fuel system while I can in the meantime before mowing season starts again.
I used WD40 as lube and a few seconds with a heat gun to get the tubes on. Also found out the 90* fittings I ordered for the lid won't work due to interference with each other. I need to get at least a couple 8ORB to 8an adapters and some 8an 90s.
Old Mar 19, 2026 | 07:19 PM
HawkZ28's Avatar
5 Year Member
Checked behind the tank. Vertical clearance but too close to the rear axle given it's thiccc....
After adding the fittings, it became "too buku" for everywhere but under the hood. It fits perfectly in the area the stock air box was. Hood closed with no issues.
snogoer
Mar 24, 2019 11:35 AM
SloSVO
May 31, 2015 12:32 AM
KleenHall
Jun 3, 2011 04:23 PM
justincredible5
Feb 3, 2010 03:39 PM
Mangled03gmc
34
Nov 27, 2008 07:53 AM
