Surge Tank
Old Jun 29, 2017 | 10:20 PM
  #21
MikeGyver's Avatar
It's a MikeGyver special. It's a stainless box with fittings welded on and a 5" V-band clamp holding on the lid. I put a fuel filler cap on as a one-way vent to break the vacuum and stay sealed to keep the fumes and fuel inside. I am using a Racetronix 4 wire bulkhead fitting.
Old Jul 9, 2017 | 08:37 AM
  #22
crashmymax's Avatar
How many pumps do you have in it? Im thinking of building/buying one. I want to put my dual walbro 450 in the surge tank and think the stock ff pump should be enough to feed the surge tank. I dont want to worry about running down to a 1/4 tank.
Old Jul 9, 2017 | 11:12 AM
  #23
MikeGyver's Avatar
Originally Posted by crashmymax
How many pumps do you have in it? ....
I was worried that running three Denso 1020s in a surge tank would overwhelm my .....
First post.
It's been great, I have a fuel pressure sensor that HP Tuners logs when I scan. No drop in fuel pressure, no glitches in the scan. If I didn't install an LED in the dash that comes on with the pumps, I would be able to completely forget that the system is in operation.
And of course I can run my main tank almost empty, just like stock, because it is stock.
Old Jul 9, 2017 | 01:30 PM
  #24
crashmymax's Avatar
sorry missed the part where it said 3 in the surge tank thought one might be feeding the two in the surge tank. That's all I'm after not having to worry about running with only a 1/4 tank left. Thanks.
