Surge Tank
Old Jun 2, 2017 | 11:49 AM
MikeGyver's Avatar
Question also is what does a 3/8 flow at zero pressure. Any back pressure is going to effect your regulated pressure.
No, that is not a question. The 3/8 line will always be at zero pressure, it's on the outlet of the regulator. If there's pressure in that hose, I will need to pull the ejector seat handle.
This line will never flow as much with the engine running as it did in my test yesterday, all pumps running and no fuel coming out of the injectors. So in my test, my regulator was bypassing 1750? hp worth of fuel according to the chart in the sticky. At WOT in my truck, my imaginary Dyno says that 750 HP of that fuel is being diverted away from the regulator, into the engine. So my theory is that the regulator will only need to bypass 1000? HP worth of fuel, and hopefully have no problem doing that.
That's what my original question was.
Originally Posted by Pat
You mean LPH. LPM would be a **** load of fuel.
Why 3? You aren't using anywhere close to 1500lph
It's probably more like half that after looking at the chart again.
Old Jun 2, 2017 | 02:24 PM
03sierraslt's Avatar
But it is a question. The regulator may bypass more then a 3/8 can handle esp given your pumps.
Old Jun 2, 2017 | 02:26 PM
MikeGyver's Avatar
Now I see your point.
Old Jun 3, 2017 | 07:42 AM
MikeGyver's Avatar
Originally Posted by thewrx
i would calculate out your fueling needs and what configuration it would take to get to what you need.
Each pump has its own fuse, I can unplug them one at a time if I need to.
Old Jun 3, 2017 | 10:50 AM
Atomic's Avatar
I have a gauge for that
Why are you using the densos? I am curious because I am the only other person I can think of that used them and they basically sucked. Replaced with 2 walbro400s and had a way better time.
Old Jun 3, 2017 | 10:17 PM
MikeGyver's Avatar
I bought them when everybody said they were good.
Old Jun 3, 2017 | 10:19 PM
MikeGyver's Avatar
Was it output or longevity that sucked?
Old Jun 4, 2017 | 01:04 AM
Atomic's Avatar
I think both really
Old Jun 27, 2017 | 08:14 AM
MikeGyver's Avatar
Originally Posted by MikeGyver
I was worried that running three Denso 1020s in a surge tank would overwhelm my Magnafuel regulator. ..
Nah, it's fine.
Old Jun 28, 2017 | 07:51 PM
crashmymax's Avatar
What surge tank are you using?
