Returnless Fuel Pump Options
Old Oct 25, 2013 | 06:15 PM
  #21
timmay208's Avatar
Originally Posted by 02b0wti3
Im also wondering about this. Ive done alot of research about a 255 for my 04 but cant get solid info...
yea i have 2 255's laying around i was going to use in my 2005. Not sure if 1 255 is good enough for 500-600hp or not with pump gas
Old Oct 25, 2013 | 08:13 PM
  #22
black4.8's Avatar
255 will do low 500's whp. I made 505rwhp w/ pressure still at 45#. Now over 600 still on single 255(returnless) and ton of meth.
Old Oct 27, 2013 | 06:56 PM
  #23
timmay208's Avatar
do you think a single 255 on returnless is good for 550?
Old Oct 28, 2013 | 06:58 PM
  #24
02b0wti3's Avatar
Okay some of you seem to have done the 255 in your returnless. What all exactly do you have to do to make it work?
Old Nov 5, 2013 | 02:29 PM
  #25
02b0wti3's Avatar
nobody? I guess I should just convert to return style
Old Nov 5, 2013 | 02:53 PM
  #26
Atomic's Avatar
I have a gauge for that
Need the pump, maybe splice some wires, and a section of submersible fuel hose, and maybe some clamps. Its not hard.
Old Feb 17, 2014 | 08:50 PM
  #27
slamdlsx's Avatar
so 255 fits and is an ok pump to swap the factory out with on a returnless setup and wont bother the fpr? My setup will be mild probably wont see the need for multiple pumps or return swap.
Wheres the best place to purchase a legit 255?
Old Feb 18, 2014 | 04:12 AM
  #28
cdub81's Avatar
255 will be fine, I ordered the AEM 320 Part#50-1200 from scoggins dickey https://sdparts.com/details/aem/50-1200
I put it in just yesterday, easy install plus I put a racetronix hot wire kit as well.Racetronix - FPWH-008 - GM SUV/Car 280 Fuel Pump Wiring Harness
Swapped pump and bought some new OEM fuel hose from here Auto Performance Engineering - Walbro fuel pumps and more
Everything is good so far!
Old Feb 19, 2014 | 07:32 AM
  #29
Flyingcat's Avatar
Best, well, easiest way to install...I know there is not an easy way...
Drop the tank..
Lift the bed..
Cut an access hole in the bed..
Bookmarked and subscribed! Great info...Thanks!!
Old Feb 19, 2014 | 08:13 AM
  #30
Atomic's Avatar
If the tank is empty drop the tank. If the tank is full take the bed off. If you are lazy cut a hole in the bed.
