Returnless Fuel Pump Options
#21
#27
so 255 fits and is an ok pump to swap the factory out with on a returnless setup and wont bother the fpr? My setup will be mild probably wont see the need for multiple pumps or return swap.
Wheres the best place to purchase a legit 255?
#28
I put it in just yesterday, easy install plus I put a racetronix hot wire kit as well.Racetronix - FPWH-008 - GM SUV/Car 280 Fuel Pump Wiring Harness
Swapped pump and bought some new OEM fuel hose from here Auto Performance Engineering - Walbro fuel pumps and more
Everything is good so far!
#29
Best, well, easiest way to install...I know there is not an easy way...
Drop the tank..
Lift the bed..
Cut an access hole in the bed..
Bookmarked and subscribed! Great info...Thanks!!
Drop the tank..
Lift the bed..
