Return style fuel system
Old Nov 10, 2012 | 01:24 PM
TRD_Tundra's Avatar
Default Return style fuel system
Any way to convert the factory returnless fuel system to return style with stock intake(maybe aftermarket fuel rails)?
It's a 2006 Silverado 5.3 FlexFuel but swapped pumps to an Aeromotive 340 and Bosch EV14 60# injectors.
Old Nov 10, 2012 | 08:49 PM
AndysC3's Avatar
get an aftermarket FPR. go from the feed to the fpr, then to the rails. route a line back to the fuel tank for the return. there might be alittle more so Ill let the more experienced chime in.
Old Nov 10, 2012 | 08:50 PM
Gadgetized's Avatar
I switched mine over to a return. You need to remove the regulator in the tank, then run a regulator on the rail with a return line. If you are referencing your boost, you will need to change the injector data in your tune.
Old Nov 10, 2012 | 09:28 PM
TRD_Tundra's Avatar
So just feed line to FPR, FPR to rails. Where do I get the return line from?
Old Nov 10, 2012 | 09:33 PM
BlackGMC's Avatar
Resident Retard
I am modifying mine as we speak. -8 feed line and -6 return.
Old Nov 11, 2012 | 08:47 AM
Gadgetized's Avatar
I used the EVAP line as a return. I will soon be doing something similar to Corey when I switch to twin 255's. I will be running a 10AN supply with an 8AN return. I will be running the feed line to an inline filter on the frame. The line will run to the back of the engine and split to 2 8's. The 8AN lines will feed the back of the rails. The fuel will exit the front of the rails, and merge into a regulator. The regulator will return with an 8AN.
Old Nov 11, 2012 | 09:45 AM
Gadgetized's Avatar
It will be set up like this, except I think I will mount the FPR off to the side so it is not under the throttle body. Plus I.don't think there is room that way.
Old Nov 11, 2012 | 10:21 AM
BlackGMC's Avatar
Resident Retard
Very nice! I will looking forward to seeing how/where you mount the FPR. I looked at mine for hours and could not find a good place.
Old Nov 11, 2012 | 11:05 AM
Gadgetized's Avatar
I have a pro flo xt intake I will be using. I need to finish the fuel rails (hopefully this week) so I can see exactly how much space I have. Right now, I think i am going to run a 180 degree fitting on the front of the drivers side rail, and put it into the regulator mounted above the rail. I will run a 90 degree off the other side of the regulator to the front of the other fuel rail. Then the return will be on a 90 pretty much running right over the rail. Well that is the plan for now.
Old Dec 5, 2012 | 09:00 PM
Dbyers2's Avatar
formery SilverSleeper1500 (12-06-2011)
Building my manifold and fuel system now
