Return-Style Fuel Conversion
Old Dec 23, 2010 | 11:41 PM
  #81
TGriz's Avatar
Originally Posted by Atomic
Supposedly very similar. as far as I know not many guys are using the densos, I may be the first on this forum doing a serious build with them
yeah man you are the first I have heard putting one in the trucks. Its definitely got my wheels turning. I am thinking Denso 1020 and a hotwire kit for my set-up. Should be able to do up to 7-800 hp I think?
Old Dec 24, 2010 | 01:07 AM
  #82
wkdivr's Avatar
Following this with great interest. Try Plumbing the reg set to 58, or whatever you're going to set it to, and see how much flow you get in the return line. There's a similiar discussion with some interesting info on the GTO site.
http://www.ls1gto.com/forums/showthread.php?t=394114
The 8.1l bucket they refer to is the same as the 04-up truck bucket.
Old Dec 24, 2010 | 01:12 AM
  #83
wkdivr's Avatar
Another good thread. I'm sure most have read it, but an interesting source for the wiring hook-up.
https://www.performancetrucks.net/fo...d.php?t=471907
Old Dec 30, 2010 | 01:41 AM
  #84
Atomic's Avatar
I have a gauge for that
I finally finshed my turbo install along with everything else and am happy to report these pumps are working well. I set the regulator to a base of 50 and have it boost referenced after that. I don't have a good way to monitor pressure drop, but I still have injector left at 6600 rpm with 12 pounds of boost on a 410, and I'm using deka 60s.
Old Dec 30, 2010 | 09:05 AM
  #85
Rick_Vor's Avatar
Nice job Atomic. That SBEC must feel like a beast running 12lbs on a 410. Do you have any ET's yet?
Thanks for the motivation to get my fuel system completed. Now I just need some dry weather. It's been raining like a SOB in CA.
Old Dec 30, 2010 | 10:54 AM
  #86
OnyxSilveradoSS's Avatar
very cool.
Old Dec 30, 2010 | 11:03 AM
  #87
Atomic's Avatar
Nothing yet, I just got it running yesterday
Its faster than my 408 with a tvs1900 though, thats for sure
Old Dec 30, 2010 | 11:26 AM
  #88
MikeGyver's Avatar
That's what I've been waiting for. Thanks, I'll get on it right away.
Old Jan 1, 2011 | 11:38 AM
  #89
Atomic's Avatar
I am trying to find a 1 psi (or lower) hobbs switch because I think having both pumps running at an idle condition is basically outflowing the regulator. Even with the stock bucket, I get fuel starvation if the fuel light is on and I give it a lot of gas.
Old Jan 1, 2011 | 12:13 PM
  #90
wkdivr's Avatar
I think you're always going to have that problem, unless you can make the venturi work, somehow. That's the biggest stumbling block to getting these dual pump systems working correctly. Of course, if you keep 1/4 tank of gas, or more, you won't have that problem.
