Return-Style Fuel Conversion
Old 12-01-2010, 01:17 PM
  #21
MikeGyver's Avatar
The bucket will serve no purpose other than to mount the gauge's sending unit by the time you whittle enough of it away to fit those pumps. You will basically have your pumps suspended in the tank with no reservoir of fuel that the bucket is intended to provide because of the holes that you make for the pumps to fit. All will be OK, though, if you keep your tank more than 1/2 full always. That is, if you can get those pumps into the tank. Like I said in another thread, they measure 55 mm in diameter, and I am pretty sure that the opening in the tank is less than 4 inches.
Now I feel like the guy that carries a needle just to pop little kid's balloons.
Old 12-01-2010, 01:29 PM
  #22
I have a gauge for that
Atomic's Avatar
I measured mine after you said that and found them to be exactly 50mm, not 55. Like I said, should be interesting
Old 12-01-2010, 01:36 PM
  #23
charcold-bowtie's Avatar
after 30 minutes I got logged into my summit account lol, It was a -10 and -6
Old 12-01-2010, 06:19 PM
  #24
MikeGyver's Avatar
Hah! I tricked you into measuring them for me. For some reason it is hard to get a print of these pumps. The guys on some of the import forums say it is because Denso doesn't want anybody making cheap copies. I say the ones that I am going to get from ebay for $144 apiece must be fakes anyhow, for that price. The dimensions that I got were from some forum, hence my use of millimeters. You might be the first person with accurate measurements on the whole internet.
Thanks.
Old 12-01-2010, 09:50 PM
  #25
Atomic's Avatar
From what I can tell there are about 4 different part numbers that refer to the same pump. I think 1020 is the toyota part number while 1252 is the denso part number. Just for the sake of completeness, the output measured 11/32" and the total body height is 99mm.
Old 12-01-2010, 09:53 PM
  #26
MikeGyver's Avatar
Is that this pump?
Old 12-01-2010, 10:48 PM
  #27
Atomic's Avatar
Yep, exact one.
I also just scored an 04 bucket to hack up instead of my original off ebay. Asking price was 65 and I offered 40 and he took it.
Old 12-02-2010, 10:28 AM
  #28
wkdivr's Avatar
Has anyone thought about using
one of these?
http://www.jegs.com/i/JEGS/555/110562/10002/-1
You couls use one large external pump/filter, and just use the bucket for the tank level sender, and the return.
Old 12-02-2010, 12:23 PM
  #29
Atomic's Avatar
I would rather the pumps be in the tank so they are able to stay cool.
Old 12-02-2010, 04:06 PM
  #30
11 Second Hall Moniter
AKlowriderZ71's Avatar
All of the external pumps I've heard were very loud. No big deal for a track truck, but annoying for a daily driver.
Quick Reply: Return-Style Fuel Conversion
