return to return less pump
I have a 00 silverado and have the return less fuel rail running a vette fuel filter for he return side. I want to swap a aeromotive 340 in and use the return less bucket. Is that a better option or should I stay return style and modify my stock bucket?
You want the 04-07 tank and bucket actually since its a lot bigger and able to hold multipe pumps without cutting it up. I would do a real FPR instead of the vette deal, and real fuel rails will probably make that easier.
The 04-07 fuel tank is not needed with a single pump. Even with 2 walbro 450 in my 00 I haven't experience any issues.
The 99-03 bucket shouldn't need to be modified in any significant way to accomodate that aftermarket pump. If anything, you may just need to enlarge the filter opening at the bottom.
Yea, you could, but if you want to do dual pumps sometime I would consider the later tank/bucket. You can do twin pumps in a 99-03 setup, but you run the possibility of sucking the bucket dry if you are low on a low fuel level.
