Post Your E85 Set-ups
Old Jun 15, 2012 | 01:27 PM
LS1FREEK's Avatar
13 Second Truck Club
Originally Posted by TimDave217
i'd also like to know what people are doing with there e85 setup's. more so what injectors people are using in 700-800 rwhp setups. I'm thinking the FIC1000's will do justice?
Yup I got those, VERY nice injectors. They are 95# @ 3bar (43.5 psi) and 108# @ 4bar (58 psi) ought to be just about perfect for 700-800rwhp, or in a lot of cases even more.
Old Jun 15, 2012 | 01:37 PM
TimDave217's Avatar
those 127's are maxed out?!?!?! i was thinking about going with those injectors also. theres some pretty heavy setup's on here.
Old Jun 15, 2012 | 01:40 PM
TimDave217's Avatar
ok that makes me feel a lil more at ease i keep seeing people using BIG injectors and some people doing it on just some 80#er's so i think im gonna try and go with those.
Old Jun 15, 2012 | 01:49 PM
LS1FREEK's Avatar
Here's some pics of mine, and TimDave217 check out my post with the pics of the injectors, FIC recommended these for 700+ rwhp.
https://www.performancetrucks.net/fo...system-501956/
Old Jun 15, 2012 | 02:34 PM
sprayedenali's Avatar
HIGH impedence....
Old Jun 15, 2012 | 03:05 PM
TimDave217's Avatar
yea i've been looking at those injectors, they are high impedance it says on his site. are you running yours at 3 bar or 4? or do you have it setup yet?
Old Jun 15, 2012 | 03:17 PM
im at 75psi base pressure right now, probably gona bump it to 80 soon, but then i cant go over 20psi bosot before my regulator runs out (only good to 100psi) but that should be fine. im running 17psi now FWIW.
Old Jun 15, 2012 | 04:07 PM
nonnieselman's Avatar
You pull trailers much
Old Jun 15, 2012 | 05:48 PM
05_quick4door's Avatar
Mine is twin walbro 255s y'd to the stock line (1/2" or so) through a pos $22 ebay regulator then factory return back to the tank. Base pressure is at 80 psi and my Siemens 80lbs(@43.5psi) and maxed smooth out
Old Jun 16, 2012 | 02:19 AM
it is a work truck after all.......
