NNBS (non flex)Walbro install ???
Old 07-26-2012, 05:34 PM
slowec's Avatar
Default NNBS (non flex)Walbro install ???
Trying to help a friend and the bucket and set up is very different from my own walbro install. Any advice and or pics of this mod would be great. I will post our mods when they are done.
THANKS!
Old 07-26-2012, 05:57 PM
slowec's Avatar
Pic of the module.
Old 07-26-2012, 06:02 PM
Mod with training wheels
smokeshow's Avatar
Atomic has a nice fuel system thread.
Old 07-26-2012, 06:23 PM
slowec's Avatar
It appears to me that the built in regulator in that dark grey piece above the pump needs to fit the pump outlet and the walbro outlet is to small. Looks like a no go without doing away with that regulator and mounting an external one. Any help or ideas...
Old 07-30-2012, 02:43 PM
carbongmc's Avatar
Im looking into doing a diesel sump at the bottom rear of my tank, then running a inline pump mounted on the frame rail off a pressure switch. This way I wont have to hack or redo anything with the stock pump and bucket assembly, and out of boost I can keep the drivibility of the stock system.
Old 07-30-2012, 07:11 PM
SLCviaAK's Avatar
Carbongmc, have you started a thread on this some where I missed? Your are turbo'ed right?
Old 07-31-2012, 04:11 PM
carbongmc's Avatar
Yes and yes. I have a few posts on the NNBS fuel systems. A walbro pump will not work. Even though you are not flex fuel, you should still have a FPCM controling the pump. A walbro will not work pulse modulated like the NNBS systems are. It will burn up under low voltage.
Old 04-16-2016, 07:20 PM
JASON 77's Avatar
What options do us non flex fuel guys have as far as pump? Stayin returnless
Old 04-20-2016, 12:27 PM
lxcoupe's Avatar
Infinite. The 04+ bucket is the easiest bucket to work with in the world. Any pump will fit and the Walbro 450 drops in like it was designed for it.
Old 04-20-2016, 12:53 PM
JASON 77's Avatar
The 450 overpowers the factory intank regulator on a non return setup.
Quick Reply: NNBS (non flex)Walbro install ???
