NNBS intake manifold swap
Old Dec 31, 2012 | 08:05 PM
MPFD's Avatar
11 Second Truck Club
When I put the cover on it you won't be able to tell its not stock?
Old Jan 3, 2013 | 03:23 PM
RedRover's Avatar
i think that the nnbs returnless rails look better too, any pros cons of returnless over return?
for my throttle body until i can afford an actual 4 bolt drive by cable throttle body can i use this with my fastory 78mm throttle body?
FAST Throttle Body Adapters 146029-KIT - SummitRacing.com
Old Jan 7, 2013 | 07:09 PM
PSI GUY's Avatar
I've been thinking about using the returnless rails when I do my swap in the near future. Instead of cutting and modifying, why not run a fitting off the schrader valve to an aeromotive or other regulator and then back to the factory return line. Makes a nicer looking setup and you can bump the fuel pressure up a bit if you start running out of injector while tuning.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
fat tony157
Jul 16, 2015 12:35 PM
blackdc3
Jul 7, 2015 07:52 PM
Black-Syde
Jul 6, 2015 02:12 PM
