NNBS intake manifold swap
i think that the nnbs returnless rails look better too, any pros cons of returnless over return?
for my throttle body until i can afford an actual 4 bolt drive by cable throttle body can i use this with my fastory 78mm throttle body?
FAST Throttle Body Adapters 146029-KIT - SummitRacing.com
I've been thinking about using the returnless rails when I do my swap in the near future. Instead of cutting and modifying, why not run a fitting off the schrader valve to an aeromotive or other regulator and then back to the factory return line. Makes a nicer looking setup and you can bump the fuel pressure up a bit if you start running out of injector while tuning.
