million dollar fuel ?
Old Nov 19, 2014 | 11:18 AM
tim wellington's Avatar
Default million dollar fuel ?
up grading fuel system .though had it map out .call to order another fitting .tech guy said i was doing it wrong he said on TURBO SET UP OR HIGH N/A. you should regulate after fuel rails not before .said i should max rails then regulate to prevent fuel starving and if regulator quit fuel want shut off.WHAT THE DEAL ANY ONE ???????????
Old Nov 19, 2014 | 11:26 AM
03sierraslt's Avatar
Regulate after rails.
Old Nov 20, 2014 | 08:44 AM
slowec's Avatar
Tell us about your system plans. I wish more people would post their fuel system choices. Mine is so stock. I need it all. ha ha
Old Nov 20, 2014 | 04:22 PM
GREENSIERRA's Avatar
I run mine after the rails
Old Nov 20, 2014 | 04:44 PM
GMCtrk's Avatar
The stock 99-03 fuel systems are really robust IMO. For gasoline with meth I think they're very capable. But I've tapped it out on ethanol around 800 rwhp.
Old Nov 21, 2014 | 04:26 PM
LS1TRUCKGUY's Avatar
you can get away with regulating before the rails if you are under 1000hp or so. the correct way to do it is regulate after the rails.
Old Nov 22, 2014 | 06:34 AM
Gadgetized's Avatar
Regulating before the rails is sort of like trying to maintain the height of a river after a dam. You can do it with sufficient flow, but it is not as accurate as maintaining the height of a river before the dam. I have mine after the rails.
Old Nov 23, 2014 | 06:24 PM
Default regulating
i guess it be done both ways .i though it was ok before rails,since thats how n.o.s and carbs are done (pre solenoids and pre fuel bowls)
Old Nov 23, 2014 | 07:30 PM
MechE's Avatar
if youre not looking for an all out setup like said above, youll be fine with regulating before the rails, just keep the regulator as close to the rails as possible
Old Nov 24, 2014 | 06:30 AM
JurgenS's Avatar
If you regulate before the rails, what pressure will you have in the rails? The only way to set it correctly is a fuel pressure regulator after the rails. Only then you will know the pressure in the rails.
