million dollar fuel ?
up grading fuel system .though had it map out .call to order another fitting .tech guy said i was doing it wrong he said on TURBO SET UP OR HIGH N/A. you should regulate after fuel rails not before .said i should max rails then regulate to prevent fuel starving and if regulator quit fuel want shut off.WHAT THE DEAL ANY ONE ???????????
The stock 99-03 fuel systems are really robust IMO. For gasoline with meth I think they're very capable. But I've tapped it out on ethanol around 800 rwhp.
Regulating before the rails is sort of like trying to maintain the height of a river after a dam. You can do it with sufficient flow, but it is not as accurate as maintaining the height of a river before the dam. I have mine after the rails.
If you regulate before the rails, what pressure will you have in the rails? The only way to set it correctly is a fuel pressure regulator after the rails. Only then you will know the pressure in the rails.
