lsa injector question
Old Jun 1, 2016 | 10:59 AM
SUTTERERMAN85's Avatar
I put a 320lph pump in a while back. Yes I was at 84% on stock LSA injectors on 93. If you go to E85 you need bigger for sure. I bet you will be around 11lbs with headers and a good exhaust.
Old Jun 1, 2016 | 02:11 PM
musclecity85's Avatar
I can deal with 84%. far as e85 I'm not sure on that yet. I might upgrade later down the road. As far as exhaust I'm thinking about upgrading to a 4inch exhaust. also does your tahoe have the fpcm? if so was the pump just a drop in and go type of deal? i was looking at an aeromotive 340 pump
Old Jun 1, 2016 | 02:48 PM
About20ninj45's Avatar
Are you wanting e85 or 93?
Old Jun 1, 2016 | 04:35 PM
just running 93 now..but e85 will be an option
Old Jun 2, 2016 | 10:45 AM
My Tahoe does not have a FPCM. It was moreless a drop in on mine. My truck was a factory flex fuel as well.
Old Jun 2, 2016 | 10:52 AM
Well I'll drop in a aeromotive 340 since my truck is flex fuel as well with no fpcm.
Old Jun 2, 2016 | 12:37 PM
Vortec350ss's Avatar
You need a lot of injector to make up for the non referenced fuel system. Also, 500hp and 16lb on a 5.3 are slightly different goals.
That makes sense. So I guess in a sense what is a more reasonable? Are you saying 500hp on a 5.3 is pushing it? And in what ways are they different?
Just trying to get a realistic understanding of where/can I wanna be power wise
He's saying 16PSI on a 5.3 with the mods you have will net you far more than 500 HP.
72's will help. Assuming the in tank pump is a 255 I think that would be enough. Do you run meth? 16PSI is a lot on pump gas.
If you go e85 you will definitely need more pump and injector. At that point I would go with a vacuum referenced regulator.
Old Jun 2, 2016 | 12:45 PM
Got you now. And I was thinking of dropping in an aeromotive 340..and no I don't currently but I was thinking about adding snow injection system
jasowole2cv
Sep 30, 2020 07:53 PM
cj847
Apr 26, 2016 06:54 AM
cj847
Mar 28, 2016 08:39 PM
KleanKustoms
Mar 9, 2016 09:47 PM
Blt2tuk
Mar 3, 2016 10:51 AM
