Low PSI at fuel rail
Engine is a '00 5.3 with a newer reternless style rail. Running a LS Corvette fuel filter/pressure regulator and inline filter. Fuel pressure at rail is ~50 PSI key on engine off and engine at idle.
Just swapped the pump from a 190lph OE style Jeep pump to a TRE 255lph pump with no change.
I had bleed off of about 1 PSI per 3 seconds prior to pump change and found a leaking fitting that was resealed. Now bleed off is about 1 PSI every minute down to about ~40 PSI then it holds pretty steady.
I have a new filter/regulator combo on the way, is there anything else I should be checking? Engine running wise starts right up and idles fine, but under load by lugging, it will stutter and hesitate.
assuming this is in a jeep wrangler? honestly you dont need that vette regulator/filter the stock Jeep regulator will supply all the fuel pressure you need... Ive had my swap done now for well over 2 yrs using the jeeps regulator, I just scaled the injectors for 50 base vs 58
im not a fan of the vette regulator idea many use, also many use the junk version...there are only 2 vette regulators that are worth a damn a actual GM one and a WIX all others are junk
up to 85% duty cycle is perfectly fine and my jeep has 50 base with its 2000 regulator
if pressure is dropping swap the filter regulator...remember its a filter first
also the injectors will only be at 80% under high rpms and full load
even 45 base which is lower then what most claim is perfectly fine for fuel pressure
