injectors size for a 6.0 600 rwhp?
Old Jan 19, 2014 | 06:50 PM
TrickTurbo's Avatar
Truck Sponsor
60lbs. Depends on the base psi your calling it.
60@ 43.5psi
Or
60 @ 60psi
We have a flex fuel 6.2 dyno'd 610 with (stock Flex fuel injectirs)
54lbs I think is what they were called.
Old Jan 19, 2014 | 06:56 PM
Chevy_King1500's Avatar
Originally Posted by TIM Z
I don't feel that 60lb injectors are going to be enough to support 600rwhp without help from meth .
If that's your plan then get a set sized for your application that will let you achieve that power goal and give you some room .
I have 60#ers but without the meth I don't think they would have cut it .
Also mine are Deatchwerks plug and play. I suggest talking to them and seeing what they have for setup . I'd rather have plug and play then re-wiring /spacing if it can be avoided.
i have the same injectors as TIM Z
71# at 4bar
$450
Old Jan 19, 2014 | 08:32 PM
TIM Z's Avatar
11 sec. Truck Mod
60@ 43.5psi
Or
60 @ 60psi
What duty cycle are they at ?
Also my 6.2 flex fuel denali injectors are 36lbhr , what ones do you have ? Are they larger on the camaro or vette ?
Old Jan 19, 2014 | 08:39 PM
TrickTurbo's Avatar
Truck Sponsor
E85 uses almost 2x the amount as gasoline.
I can not say whatvthe duty cycle was.
customer is in Florida.
He posted his build on here. Stock fuel system ls9 cam.
605hp @ 11-12psi.
Old Jan 19, 2014 | 08:56 PM
timmay208's Avatar
generally e85 is 20-30% more not 100%
Old Jan 20, 2014 | 10:08 AM
kbracing96's Avatar
SD60's are fine for 600, they are actually 72's at 4 bar (58psi) I made 800 hp with them at the track, maxing out the 340lph fuel pump but was also running meth with a single 15gph nozzle. SD60's and a Walbro 450 would be my recommendation for 600 even with out meth.
Old Jan 21, 2014 | 06:52 AM
6.0l RST's Avatar
so would these be good for 800 hp with some meth
Racetronix - LU108 - 80 lb/hr D4 High-Z Fuel Injector USCAR
Old Jan 24, 2014 | 08:05 PM
darnie's Avatar
Originally Posted by Alpinestar
x2. A lot of people, including myself, run Siemens Deka 60lb EV1 injectors without any problems. If you go that route be sure to get the right sized o-rings and you will need EV1 connector adaptors as well. You will also have to space your fuel rails up a bit.
Not to thread jack, but this is the issue I'm having. Last 2 months I can't seem to get my divers rear injector to seal. I'm running the siemens 80s with a ls1/ls6 fuel rail and its leaking like crazy were the injector meets the rail. I got the old style o-rings installed and just picked up a set of new style and some ls6 vette o-rings see if it will seal. Idk what else to do?
Old Jan 24, 2014 | 08:16 PM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
def go with the 80lbs ones to be safe call up Fuel injection connection and they'll set you up with the right ones
Old Jan 26, 2014 | 06:03 PM
Vortec350ss's Avatar
This. Kurt and I both run FIC 83# injectors at 58psi. They're rated on his site at 3 bar to be 72#
