Injector size for turbo set
Hey i have a LS1 building the motor and running a turbo set up. Wanted to see how much the factory system would hold if i put two 255s in tank? Wanting to eventually run 15-20PSI with the turbo set up. Would like to do everything once the right way. What size injectors and what the factory fuel rails will manage?
I have 1 aeromotive stealth 340 fuel pump in the tank dash 6 fuel line with return and a adjustable pressure regulator on a 6.0 with 2.9 whipple on stage 2 ported L92 heads 600+ lift cam 8 lbs boost and injector dynamics ID 850 85lb injectors they run at 70 % duty cycle . we are running 39.5 lbs fuel pressure to get more volume
maxspeed05V
Jul 19, 2015 07:08 PM
