Injector size for turbo set
Old Jul 6, 2012 | 07:10 PM
904silverado's Avatar
Default Injector size for turbo set
Hey i have a LS1 building the motor and running a turbo set up. Wanted to see how much the factory system would hold if i put two 255s in tank? Wanting to eventually run 15-20PSI with the turbo set up. Would like to do everything once the right way. What size injectors and what the factory fuel rails will manage?
Old Jul 6, 2012 | 07:49 PM
lglowe's Avatar
Return or returnless fuel system and e85 or just 93 gas?
Old Jul 6, 2012 | 11:17 PM
Return and 93 gas
Old Jul 8, 2012 | 12:50 AM
PRO TOUR HOE's Avatar
I have 1 aeromotive stealth 340 fuel pump in the tank dash 6 fuel line with return and a adjustable pressure regulator on a 6.0 with 2.9 whipple on stage 2 ported L92 heads 600+ lift cam 8 lbs boost and injector dynamics ID 850 85lb injectors they run at 70 % duty cycle . we are running 39.5 lbs fuel pressure to get more volumeName:  OptimaTahoe3.jpg
chopperloco
Jul 10, 2016 10:45 PM
maxspeed05V
Jul 19, 2015 07:08 PM
black6spdz
Jul 16, 2015 01:32 AM
kdw8888
Jul 9, 2015 10:52 PM
jrplz
Jul 9, 2015 12:07 AM
