How does everyone have their aftermarket FPR mounted in a NBS ?
Old Aug 13, 2016 | 02:45 PM
zblee's Avatar
Originally Posted by flatblack83
Wouldn't it be better to mount it away from the motor, like behind it so incase their is ever a problem gas doesn't leak all over the hot motor..? I bolted mine behind the intake in that small space. Then the line from the rail to the return is also short.
yeah this is probably the area i will have mine as well, similar to MikeD.'s
Old Aug 13, 2016 | 06:26 PM
ironcityboom's Avatar
Not that I would but it should be a non issue, that'd be like mounting your fuel rails in the fender wells in case they leak....
Old Aug 13, 2016 | 07:52 PM
03sierraslt's Avatar
Vac ref is stainless hardline to my vac manifold in drivers fender well.
Old Aug 13, 2016 | 08:28 PM
zblee's Avatar
where you pulling vacuum from for your manifold?
Old Aug 13, 2016 | 08:42 PM
From my lower blower manifold.
Old Aug 13, 2016 | 09:19 PM
Oh you fancyy huh lol..
Old Aug 14, 2016 | 06:42 AM
Settle down skippy.
Old Aug 24, 2016 | 04:24 PM
slowec's Avatar
Aren't you supposed to keep it off the firewall per NHRA track regs? Pretty sure I read that somewhere.
Old Aug 24, 2016 | 06:29 PM
BlackGMC's Avatar
Resident Retard
Yep. You will fail technif it mounted to the firewall. That is why i mounted mine where i did.
Old Aug 24, 2016 | 07:58 PM
Also why mine isn't also. It's close but not on the firewall or attached too it in any way.
