going return style....
Old 11-17-2013 | 10:48 AM
  #21
ak2007r6's Avatar
Depending in what FPR you have if you run it like my pic above you shouldn't have an extra port
Old 11-17-2013 | 01:22 PM
  #22
oakley6575's Avatar
Originally Posted by darnie
So the regulator goes post fuel rail? Strange... but got it. If i tun it like andys i just olug off te extra port in the regulator correct?
Yes correct. Both methods work. There is a little bit more plumbing to do if you use aeromotives way.
Old 11-17-2013 | 01:47 PM
  #23
darnie's Avatar
both ways just as efficient? and heres a link to the regulator i have. it has 2 feed ports and a return port on the bottom
Aeromotive 13129 Aeromotive Compact EFI Fuel Pressure Regulator - Free Shipping on All Orders @ JEGS
Old 11-17-2013 | 01:54 PM
  #24
oakley6575's Avatar
I'm running the same one but I currently am using the right inlet as an outlet. I hate my returnless fuel rail.
Old 11-17-2013 | 02:08 PM
  #25
darnie's Avatar
so more along the lines of this ? i can eather run the lines like this or use the stock feed as a return and hook it stright to the regulator and then use the new lines to run the feed? whatever you guys think?
Old 11-17-2013 | 02:17 PM
  #26
darnie's Avatar
heres a list of all the parts and stuff i have
fuel rails
LS1 LS6 8AN High Flow Black Fuel Rails w Fittings Nylon Hose Hardware | eBay
for the stock fuel feed
http://www.summitracing.com/parts/rus-640690
the fuel pressure regulator
http://www.summitracing.com/parts/aei-13129/overview/
washers
Pre 79089 5 Pack 8 An Bulkhead Teflon Sealing Crush Washers Fuel Oil Coolant | eBay
bulkhead fitting for the tank
http://www.summitracing.com/parts/ea...6erl/overview/
6an fittings
Blemished 6 An Male to 6 An Male Union Blue Anodized Aluminum Fittings | eBay
plug if needed
http://www.summitracing.com/parts/sum-220630/overview/
Old 11-17-2013 | 05:44 PM
  #27
oakley6575's Avatar
You can run the stock feed line as the return but definitly don't use it as your main feed like your diagram shows. Since you are turbo'd and are capable of making good power, run a -8 feed and fuel crossover. Then come out of the passenger rail with a -6 fitting to the regulator. I would want to run as much fuel volume by the injectors pre regulator as possible.
Old 11-17-2013 | 06:01 PM
  #28
darnie's Avatar
Hummm... well if i do that ill have to buy all new fittings and stuff to go 8an ill see what i can do.
Old 11-17-2013 | 06:02 PM
  #29
blue0453's Avatar
I did mine like this. -8 bulkhead with -8 feed with -8 in/out inline filer to regulator. Then -6 to factory fuel rails with russel quick connect fitting. Then -6 to factory feed for my return with russell quick connect fitting. I'm running 17ish psi on this setup on e85 running dual 450s.
Old 11-17-2013 | 06:16 PM
  #30
darnie's Avatar
Im only planning on running 91, with 12lbs max. Would i need a inline filter as well? Its got the one in the tank? Sorry new to all this.
Quick Reply: going return style....
