Fuel Pump/System Troubleshooting
Old May 20, 2021 | 07:36 PM
snogoer's Avatar
Default Fuel Pump/System Troubleshooting
I need a little troubleshooting help from some more knowledge people than myself. I have been driving my truck for most of the winter and this summer so far, It has a Walbro 450 return style fuel system I installed. The issue I am having is a few days ago it randomly started to not start or show fuel pressure on my gauge when I would turn the truck key into accessory and or try to start the truck. But if I would just keep trying over and over again to start the truck eventually (luckily) it would just randomly fire up and run like normal and show the proper fuel pressure. But its now happening more often and it will only eventually fire up after numerous start attempts. Sometime not even showing pressure on my fuel gauge until after the truck has fired up. Can anyone give me some input on where you think the issue is. The system only have about 3000 miles on it.
Old May 21, 2021 | 07:35 AM
MikeGyver's Avatar
Did you use Gates submersible fuel hose in the tank? If so, it has probably failed. OEM style corrugated nylon is the best bet for submerged hose.
Old May 21, 2021 | 08:53 AM
snogoer's Avatar
Yes I used the gates corrugated fuel line in the tank
Old May 21, 2021 | 06:44 PM
MikeGyver's Avatar
I didn't know they made it. I was talking about their hose that looks like normal reinforced rubber fuel hose that Gates advertises as submersible. It gets soft and splits in short order. I'm not familiar with Gates corrugated submersible hose, and a quick Google search didn't find it.
alanmichael.gentry
May 28, 2012 09:32 PM
cueball
Feb 17, 2011 04:06 AM
lpguy
19
May 14, 2008 10:47 AM
Rollen48
Oct 16, 2005 01:03 PM
