Fuel Pump Signal Wire
Old Mar 31, 2014 | 09:12 PM
Funkster's Avatar
12 Second Club
Default Fuel Pump Signal Wire
I am wiring up my Hobbs switch and getting ready to solder up the PCM wire on the relay. My question is, what pin on the PCM is it and or what color is it?
Old Apr 1, 2014 | 12:57 PM
Funkster's Avatar
12 Second Club
To make it easier I may just pull from the factory fuel pump harness if possible. In that case I am still curious what color the wire is?
Old Apr 1, 2014 | 01:03 PM
Atomic's Avatar
I have a gauge for that
Light green i think
Old Apr 1, 2014 | 01:13 PM
Funkster's Avatar
12 Second Club
Originally Posted by Atomic
Light green i think
Noted, I have seen a few references to R9 on the PCM too, but not sure if that applies to the trucks as well.
Old Apr 2, 2014 | 09:08 AM
Funkster's Avatar
12 Second Club
Well I failed at finding the wire last night when I briefly looked.
I looked for a light green wire on the fuel pump harness with no luck. I was wondering though, this wire is just essentially acting as a 12v switched correct? If so it could be a lot easier. Such as just tapping off the factory fuel pump fuse in the fusebox, etc.
Old Apr 2, 2014 | 10:25 AM
Atomic's Avatar
The fuel pump harness is post fuel pump relay. A signal wire is the one that activates the relay. The positive wire actually going to the pump is purple or grey I think. The light green wire I was referring to is from the PCM to the fuel pump relay in the fuse box.
Old Apr 2, 2014 | 12:58 PM
Funkster's Avatar
12 Second Club
OK, that makes sense. So basically find the fuel pump relay in the fuse box and tap off the green wire on that. I am terrible with figuring this kind of stuff out which I bet is very obvious. That line is just a 12v switched in effect then it sounds?
Old Apr 2, 2014 | 02:11 PM
Atomic's Avatar
Yea, if you look at the relay, 85 is a ground, 86 would be the light green one from the pcm, 30 would be to battery, and 87 would be to pump.
Old Apr 3, 2014 | 09:18 PM
Funkster's Avatar
12 Second Club
Nevermind, I found Atomic's picture in another thread. I was looking for a lime green, now I see which one it is.
wrb002
Aug 31, 2015 12:00 PM
roprisiu
Aug 9, 2015 10:47 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
