Fuel pump setup for PT88 turbo
Old Jan 14, 2013 | 12:40 PM
silverz28camaro's Avatar
Default Fuel pump setup for PT88 turbo
Right now I just got the setup running on speed density..
-364 cu.in
-ported 317s
-ls6 cam
-ss4000 stall 4l60e
-3.08 gears
-10.4 compression
I have 60lb injectors with stock f-body railes and lines single intank racetronix 255 pump..
Its going lean at 5000+ close to 13 A/F.....
I was wondering if a single badass pump is availiable, or is a dual pump with twin 255's the way to go, one on the hobbs switch? or do people run both all the time?
Old Jan 14, 2013 | 01:00 PM
chevrolet all the way's Avatar
i run 2 255s always and have for over 20k miles. mine is only a 5.3 but at 20 psi im still just fine.
i think you will be out of injectors at a low boost also
Old Jan 14, 2013 | 05:22 PM
quicksilverado's Avatar
Once you get the fuel pumps you will probably need bigger injectors too.
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
