Fuel Pump,Hot wire kit?
Old May 12, 2014 | 03:46 PM
rnrnoriega's Avatar
Default Fuel Pump,Hot wire kit?
Need help again,I have almost everything together,cam,l92 heads ,intake, injectors (60lb),lifters, pushrods, nitrous 150 wet shot . but my question is, do i need bigger fuel pump and hot wire kit. i do which brand did you guys recommend for my setup. is a 2003 silverado
any help will be appreciated.
Old May 12, 2014 | 07:16 PM
Smokymance's Avatar
id try to post this on the technical section! im sure many people will chime in and help...
Old May 13, 2014 | 12:01 AM
rnrnoriega's Avatar
nothing ? nobody?
Old May 13, 2014 | 02:19 AM
lsxperformance's Avatar
My cam,ls3 headed Holley intake headers combo is only at 30% duty cycle with a stock pump and 60lb inj. 06 truck 6.0l I was thinkin about doin a walbro 400 with a hot wire kit haven't done one yet has been fine soo far.
Old May 13, 2014 | 02:27 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by rnrnoriega
nothing ? nobody?
For starters, posting a fuel system question in the Projects section won't net you a whole lot of help. I moved it to the Fuel System section for you.
And to try to answer your original question, upgrading your fuel pump and harness would be a smart move. Especially if your nitrous kit isn't on a standalone fuel system.
Old May 13, 2014 | 11:13 AM
GREENSIERRA's Avatar
I was told by FIC that I would need the 340 pump with my setup and spray. I have the pump and hotwire kit but just need to install it
Old May 13, 2014 | 02:45 PM
rnrnoriega's Avatar
my bad. and which brand you think is good one?
5.3Okasai
Mar 9, 2022 01:07 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
wrb002
Aug 31, 2015 12:00 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
