Fuel pressure sender to fuel rail fitting?
Old Jul 18, 2012 | 12:58 PM
Ferocity02's Avatar
Default Fuel pressure sender to fuel rail fitting?
What is the thread size of the fuel rail where the schrader valve is? Looks like -4AN, can anyone confirm this? I need to get a fitting to attach the fuel pressure sending unit to the fuel rail.
Old Jul 18, 2012 | 01:01 PM
nonnieselman's Avatar
-4an or #4 hydraulic fitting.
Old Jul 18, 2012 | 01:03 PM
need something like this
http://brennaninc.com/ProductDisplay...tem=6506-04-02
Old Jul 18, 2012 | 01:10 PM
search
EAR-916104ERL
FRA-491001
on summit
Old Jul 18, 2012 | 02:00 PM
Ferocity02's Avatar
-4AN it is, thanks!
Old Jul 18, 2012 | 06:06 PM
AndysC3's Avatar
The the schrader valve is -4an?
Old Jul 18, 2012 | 07:22 PM
2doorfury's Avatar
how would this work?? wouldnt you need some kind of special fitting to push in the schreador valve?? ive been wondering if you could run a fuel pressure gauge off the test port..
Old Jul 18, 2012 | 07:29 PM
AndysC3's Avatar
I have the valve removed in my test post. Im going to swap to an aftermarket fpr so I need to know the size of the schrader
Old Jul 18, 2012 | 07:37 PM
Ferocity02's Avatar
There is a plastic cap that screws onto the fuel rail over the schrader valve. I believe it's threaded to -4AN, at least it was on my Z28. The schrader valve inside can be removed easily so you can get a pressure reading.
Here is a thread I made 7 years ago, but it was for my Z28, which I'm guessing is the same thread, but different location, as my '01 Silverado:
https://ls1tech.com/forums/fueling-i...ender-pic.html
And another one:
https://ls1tech.com/forums/fueling-i...read-size.html
Old Jul 18, 2012 | 07:46 PM
Ferocity02's Avatar
Metco makes the adapter, but putting two together is cheaper.
GM Fuel Rail Adapter, Fuel System Components: Metco Motorsports
